Error when importing pnt file
  • 1.  Error when importing pnt file
    Posted 02-15-2019 08:10
      |   view attached
    I get the following error message when I try to import he attached .pnt file.
    I can import other pnt files with no issue.
    Thank you.
    Attachment(s)
  • 2.  Re: Error when importing pnt file
    Posted 02-15-2019 08:43
    You have one column that isn't tab delimited (8x6 tee).  I was able to drag the file into TBC after adding a tab after the description there.
    I had trouble importing/dragging in a PNT file earlier this week which was exported from Earthworks.  I just made a new import format (which actually matched the existing PNT format) and it worked fine.  I don't know the issue.  Check Tab on 8x6 Tee
  • 3.  Re: Error when importing pnt file
    Posted 02-15-2019 12:36
    Was this an Earthworks File Pat?
    Looks like maybe an issue with Earthworks writing the PNT File
    I can send it on to the Earthwork Boys to take a look at if this is the case
  • 4.  Re: Error when importing pnt file
    Posted 02-15-2019 12:58
    Alan,
    Yes it was a PNT file from an earthworks machine. It looks like the operator added a smiley face in the description and I believe that is what was causing the issue.
    Maybe there needs to be a restrictions are characters that can be input in Earthworks.
  • 5.  Re: Error when importing pnt file
    Posted 02-15-2019 12:56
    I think it might be the operator adding unrecognized characters. I deleted the smiley face and issue solved.
    We encourage smiles but they do not bode well in point files.
