Erratic Results for reference line in Plan set Profile
  • 1.  Erratic Results for reference line in Plan set Profile
    Posted 02-08-2019 06:27
      |   view attached
    I am getting erratic results in the in a profile plan set for a reference lines. I have two references line I am trying to show in my profile 24 ft left of CL and 24 right of CL. The 2D and 3D data all seem to be correct but in the profile view they are not mirroring what the plan and 3D are showing. In the image below the two red lines, 24 ft right of cl, should only be one continuous line but right around station 4+55 the red line "flat lines" and then the second half of the line starts at ~  sta 5+10. 24 ft left of CL "flat lines" as well right around station 4+65.
    The data that I am computing based on the reference lines appears to be correct.
    Data for Viewing information:
    • View Filter - Design - Hetnar's Profile
    • Plan Set - Plan and Profile Hetnar's Way
    Let me know if you need any additional data.
    Attachment(s)
    zip
    213373 - The Orchards.vce.zip   14.36 MB 1 version
  • 2.  Re: Erratic Results for reference line in Plan set Profile
    Posted 12-31-2019 06:53
    I am still having issues with this. I just reloaded this project and updated my profile sheets. This does not appeared to have been addressed.
