The profile Table is for Metric Users and typically European / Australian Style Profiles and Sections. The way these regions generate their Profiles is without Grids (as per US Methods) and they have "Drop Lines" from the profile and then Labels in Tables below the profile as shown below
In this mode you do have a Datum Elevation that can be defined and then the Table that you define below the Profile will occupy space of the available Profile Box, so this when used in combination with the Grid Method of plotting profiles will have an effect - however the Grid Method and Table Method of creating profile drawings were designed to be exclusively different, so if you use them in combination (not designed to do that), you will get some unexpected results for sure, however you may be able to find ways to use the Table Settings to push the profile Higher in the available drawing box - and then not display the Tables at all (switch off the content
If you go into the Profile Table and do the following, it will have the effect of pushing the profile Up in the drawing pane
- Go to Profile Table and set the check box to "Draw" - this alone will force some additional space below the Profile which may be sufficient for what you are trying to achieve. In my test case clicking this moves my test profile up by ~1 major grid interval. This always depends on the size of the sheet, the height of the Profile drawing Box, the vertical exaggeration, your grid settings and how many labels you have and where they sit above and below the profile, as well of course as the shape of the profile.
- Now other settings you make will dictate how much space will be consumed by the table below the profile - ie the Kink Row Height (this kinks the drop lines so that text in the tables do not overwrite each other in the table below), row height (each label in the table goes in a row, each row has a row height to accommodate the labels), the number of table rows you want (for the values like Station, Elevation, Cut Fill, HAL Geometry, VAL Geometry etc. Each addition you actually draw will consume space below the profile, however turning these on will likely overwrite on the Grid (and this is the area where I doubt you will get a good solution as Grids and Tables were not designed to work together.
Hope that this helps here guys
