Alan,
Short Term -Solved
This works great. Thank you pointing this out. That does help to quickly manually manipulate the dynaview and fit what you need if the automated view does not grab it.
Long term - #enhancementrequest
I am hesitant to say it solves the issue because we do a lot of these subdivisions (shown below) and every time I make an edit in profile settings and rebuild sheets I need to remember to go back and tweak the plan view dynaview. This definitely adds another step to forget when you are throwing together deliverables. When I choose to build sheets, I want to get that sheet as close to perfect as possible so I don't have to worry about missing something if I am in a time crunch.
In an effort to automate the process more I would to put in an #enhancementrequest for starting and ending station offsets in the Plan settings.
Suggestions:
- Have the profile run a check on the alignment to see if:
- The ending station is within a range window ( something like +/-.5 horizontal) of the rest of the alignment
- If it is, run a distance check between the 0+00 and the ending station and the further station from 0+00
- Use the furthest linear distance from 0+00 as the plan end
- Allow for offset inputs form the starting station and ending station
- At the start:This would allows you to apply a negative offset to see more of the plan view at the start of an alignment
- At the end: this would allow you to see more of the plan view
- Or a linear distance from 0+00
There will always be need for manual manipulation (you cannot automate everything...yet) but if we can apply offsets and have the profile plan view spit out the same results consistently it makes things a lot easier when there are revisions or updates to entities. That saves me and other users from going through all of the workarounds we had to perform to get to the final product and make sure you updated them as well. Something I feel is part of the issue with engineering plans I see today. A lot (not all but a lot) seem to use methods that are do not dynamically update with changes, so if they change a cross sections it does not regen everything else and you run into issues with plans sheets, profile, cross sections and typicals all potentially differing. What is right? Those are the worst.
Which brings me to another thought, could we flag cross sections sheets and profile sheets that need to be updated because of changes to a surface? #enhancementrequest
Cul-De-Sac Examples:
This project consisted of two Cul-De-Sacs both similar shape
This project had 2 that were tear drop shaped but same issues
Another example
Thank You!
