Feature Request - Smart Text - Missing an option for cut and fill name
  • 1.  Feature Request - Smart Text - Missing an option for cut and fill name
    Posted 09-10-2019 05:04
    In the picture below, I was trying to label the cut and fill grid surface using smart text. I could not find a sequence that worked though. Is this possible with the current codes at our disposal? If not, can we get a code for the cut and fill surface name please? #enhancementrequest
  • 2.  Re: Feature Request - Smart Text - Missing an option for cut and fill name
    Posted 09-10-2019 05:06
    Maybe also initial surface and final surface
  • 3.  Re: Feature Request - Smart Text - Missing an option for cut and fill name
    Posted 09-10-2019 07:47
    It's just the name of the surface:
    Name= @<NM,O>@
    Fill= @<OD,O,vf>@
    Cut= @<OD,O,vc>@
    We don't currently support the initial and final surface.  I will add it to the list of potential enhancements.  Until then you may want to name your cut fill map with the names of the surfaces being compared.
  • 4.  Re: Feature Request - Smart Text - Missing an option for cut and fill name
    Posted 09-10-2019 08:07
    It appears that it does not support the stored measurements name. It will support the surface name both regular and cut and fill. Could the support for stored measurements name be added please?
  • 5.  Re: Feature Request - Smart Text - Missing an option for cut and fill name
    Posted 09-10-2019 08:58
    The name of a cut fill map is currently supported, but not the name of a surface volume grid.  I have added this one to the enhancement list also.
    tim
  • 6.  Re: Feature Request - Smart Text - Missing an option for cut and fill name
    Posted 04-22-2020 03:04
    This has been address in a recent build of TBC.
