You can create a Planar Surface using the Create Planar Surface Command and then use Change Elevation Command to drape the lines on the Planar Surface - that works well today and gives a good result. Then you can delete the planar surface when completed as there is zero dependency of the lines on the planar surface.
Here is an example where I did this - the ling straight lines are 1' contours on a 10% slope. The perpendicular lines are "construct lines" to define the orientation of the plane slope. The other lines - the lozenge and one other line are the Parking Island lines.
I picked all of the lines and draped them on the planar surface (Green surface behind the linework).
I also sent you an email separately on this Pat
