Feature Request - Snap to vector pdf data once import
  • 1.  Feature Request - Snap to vector pdf data once import
    Posted 09-11-2019 09:36
    I thought this was mentioned before but couldn't find anything on the community.
    The ability to snap to a point on a vector PDF would be very useful. Yes you can import the linework but you also get all of the extra junk that you may want and then have to deal with cleaning and deleting this, creating more work than a simple snap to 2 points would be. Sometimes you just need to create a quick phasing line as shown in my video.
    Please consider. Thank you!
  • 2.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-11-2019 10:25
    I will add this to the list of entrancement requests.  Note that we have a very large list and we are only able to implement a fraction of what we would like to do.  Keep them coming, we rank these based on effort required and anticipated value to customers.  Every release we take the most valuable ideas in addition to our larger goals to make a release.
    tim
  • 3.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-19-2019 08:37
    If they add the feature (please do), there needs to be a seperate toggle button handy, preferably added to the status bar separate from the osnap toggle at the bottom of the main window.
  • 4.  RE: Re: Feature Request - Snap to vector pdf data once import
    Posted 01-15-2023 16:04
    Tim,
    Can this be added to Place Image as well?  When placing the first Vector PDF, it would be nice to have the Save Snap Locations option as well.
    Tim McCann
  • 5.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-11-2019 16:44
    I agree with Pat. I have a ton of clients that complain about this all the time.
  • 6.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-12-2019 08:13
    I second this request.  Bringing in all of the vector information and then cleaning it up just to do something simple is a big time waster.  This feature would help tremendously.
  • 7.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-14-2019 06:20
    I agree that this would be very helpful.
  • 8.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-14-2019 10:45
    would be helpful for sure
  • 9.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-19-2019 07:41
    Just like in the Digitize Cross Section.  Such a Pain to clean up.  it would be nice to show vector data so you can snap to the lines you want to draw quick lines.
  • 10.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-19-2019 08:04
    Yes please!
  • 11.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-23-2019 12:16
    I would like to see this function as well!
  • 12.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-24-2019 13:31
    Frank
    You can already use Vector data to select linework in Digitize Section and it can be turned on and off using CTRL V. it doesn't snap to nodes, but it does snap to the lines and extract the lines automatically - good for existing for sure.
  • 13.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-24-2019 15:14
    Agree with all of you that this would be a great addition - however .... To do what you are all asking for try the following
    1. Go ahead and import the Vectors for each sheet. After import relayer all of the imported Vector Data to a Layer called PDF Linework - Sheet 1. Set the layer Color to Light Grey (I think that you will want to see the linework not just the snap points if you are trying to draw over linework) and set the lineweight to something like 0.2 mm so it is easy to see on the Black Linework of the PDF Sheet.
    2. Set your Snaps to use End Point, Free Point and Near Point. Free Point is optional if sometimes you want to add data that is not in the Vectors that you imported.
    3. Now you can trace lines using bolder colors like red or Blue with lineweight .5 and use the Vectors as snapping locations.
    4. If you have multiple sheets of PDF data - import each set of linework and Relayer it by Sheet to different Layers - that way you can delete it anytime you want, and you can turn lines on / off by layer for each sheet as needed
    5. Before you Relayer the imported vectors, you may want to Name the Objects using the Layer Names of the imported Vectors. That way you can select by name to get all the lines (like contours) that may be on one layer initially back onto one layer pretty fast when you realize that this layer is actually useful data. This would apply to non Bold Lines that are drawn as a single line in the PDF.
    While not 100% what you wanted, it works exactly like you wanted - OK it adds a Layer per PDF Sheet imported and adds Entities to a Project making it bigger - however that is only in theory because if we held all vectors in background we would be doing the same thing so not really a saving in Size or Speed of use, just in the visibility of the objects. You can turn the "Selectable" flag on or off on the PDF Linework Layers as needed to stop inadvertent snapping or selecting if needed. I have used this approach quite a bit and what I do like about it is that if there is a layer of Good Linework that I want to use I can select by Name (Advanced Select) and get the data and relayer it for e.g. Contours or Buildings where it makes sense to do so that can save a lot of digitizing time.
    This works for Plans and we have some exciting things up our sleeves for Sections .....
  • 14.  Re: Feature Request - Snap to vector pdf data once import
    Posted 10-03-2019 12:38
    Alan,
    What would make this process easier would be the ability to set a prefix and layer group to lines imported from a pdf. This would help us organize the lineworks data from the pdfs. Linework imported from a pdf is not tied to the pdf, so if you already have a pdf imported into the project it can be a nuisance to separate data.
    Yes you can select newly imported vector linework from a pdf, export it out as a dwg/dxf, re-import and set a prefix but this is a lot of extra steps that should be available. This is especially a pain for revisions. Using the pdf over the CAD file is sometimes quicker because you just need to bump out the curb, move a sign, make small adjustments or tweaks. It doesn't always warrant going through the whole CAD file and you may miss something going this route.
    Things that would help the current process until pdf vector snapping is implemented:
    1. Option to set a prefix to imported layers
    2. Option to set a layer group
    3. Have the lines imported from a vector pdf be tied to the pdf
       - This would allow users to select all members
    -Useful when a revision comes out, users could grab all and delete
  • 15.  Re: Feature Request - Snap to vector pdf data once import
    Posted 10-03-2019 12:55
      |   view attached
    I have a "PDF Layers" layer group in my template, and when I import vector
    information, all the vector layers automatically have layers that start
    with PDF.  I then go into the Layer Manager, shift+select all the layers
    that start with PDF and move them to the "PDF Layers" layer group.  I can
    then turn that whole group on and off as I need the vector information.
    On Thu, Oct 3, 2019 at 3:38 PM plheureux@severinotrucking.com <
  • 16.  RE: Re: Feature Request - Snap to vector pdf data once import
    Posted 12-15-2020 09:01
    Alan - The issue with importing vector data I have found is on large projects it really really slows down the TBC file to have all the data turned on.
    Jordan Swanson
  • 17.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-25-2019 05:05
    Thank you for that workflow.  I will be trying it.
  • 18.  Re: Feature Request - Snap to vector pdf data once import
    Posted 09-25-2019 05:22
    One other step I have started to do with importing sheets.  Doing a Save As for only importing PDF Sheets then export any line work from there.  that way I don't over crowd my main project.
  • 19.  RE: Feature Request - Snap to vector pdf data once import
    Posted 12-15-2020 09:04
    This would be an absolutely awesome feature.  Going through the entire process to import vector data and sort through the layers is such a pain.  Having all that data in your file also causes performance issues (it's not a CPU thing).  This seems like an easy add, because when your in the "georeference vector pdf" command it snaps to the data there.  Simply just give us a toggle option in the properties for georeferenced vector PDF's.
    Jordan Swanson
  • 20.  RE: Feature Request - Snap to vector pdf data once import
    Posted 12-15-2020 09:07
    This feature enhancement would be incredibly helpful. Being able to snap to georeferenced pdfs in business center would provide value, save time drafting, and eliminate the need to import vector PDF linework, relayer, delete lines I don't want, etc etc etc. My files get bogged down occasionally when I import vector pdf data, so I usually end up creating a "sacrificial" file to export linework into the actual file I'm working in. Please include this enhancement soon!
    Riley Thoss
