Feature Definition Manager Exception
  • 1.  Feature Definition Manager Exception
    Posted 08-12-2019 03:59
    I am getting the following exception when trying to edit a fxl file.
    I do not believe it is the fxl file because I have used it successfully in the past but I am unsure. it is also giving me errors when I try to create new features from scratch.
    Thanks!
    Attachment(s)
  • 2.  Re: Feature Definition Manager Exception
    Posted 08-12-2019 08:24
    I forwarded to QA to take a look at this for you
  • 3.  Re: Feature Definition Manager Exception
    Posted 08-22-2019 05:23
    Did QA come back with anything? I am wondering if I should start from scratch.
  • 4.  Re: Feature Definition Manager Exception
    Posted 08-22-2019 08:20
    No they didnt - I will need to take a look at this Pat - apologies I had
    hoped someone else would pick up on this one.
    On Thu, Aug 22, 2019 at 6:23 AM plheureux@severinotrucking.com <
  • 5.  Re: Feature Definition Manager Exception
    Posted 08-22-2019 11:12
      |   view attached
    I will wait til we discuss this one on the phone, however I just tried this in 5.1.1. and it imports OK and allows me to edit it in the Project Explorer OK and then Export it again and then use it in another TBC project. I wonder if it is the Editor Version that you are using - maybe that is older than the current version - we are moving to editing the FXL data in the Project Explorer directly and phasing out the FXL Editor - you just import the FXL to an empty or working project - the FXL gets added to the Project Explorer and then you have RIght CLick edits to modify and add categories, Point or line features etc. I created a new category, added a new point style and Exported the FXL all ok and enclose it here - I tried it in both 5.1.1. and the next release to see if there were any issues - maybe what I did has updated the file and cleared the issue - let me know - it should not throw an exception of course - but I have not been able to reproduce it with the FXL you sent me.
    If you get the problem again let me know
    Attachment(s)
    zip
    Sev fcl.fxl.zip   1 KB 1 version
  • 6.  Re: Feature Definition Manager Exception
    Posted 08-23-2019 04:58
    That seemed to work with no issues. Plus the interface is way better. Thanks for the recommendation.
  • 7.  Re: Feature Definition Manager Exception
    Posted 08-23-2019 06:11
    I didn't know you could modify Feature Definitions in TBC (Really haven't messed around with them until two days ago). This so so much smoother than using the manager!
  • 8.  Re: Feature Definition Manager Exception
    Posted 08-23-2019 06:23
    We have to keep some secrets from you Eric!
  • 9.  Re: Feature Definition Manager Exception
    Posted 10-01-2019 07:38
    This is new to me on editing FXl in Project Explorer.  This is great and helpful.  I could not fiqure out how to add new codes to my list and now I found how to add.  The field crews are always adding their own codes and we manually connects points or use the Connect command.
    Now to figure out how to generate lines as they do the topo in Survey Pro.  Make it easier for me in the office.
