Plane Surface - Apply a boundary after it has been created
  • 1.  Plane Surface - Apply a boundary after it has been created
    Posted 08-27-2019 07:46
    Is there no way to apply a boundary to a plane surface after it has been created? I have a plane surface that I want to clean up. I could delete the surface and start from scratch but I do necessarily know what is tied to this surface and I don't want to break all of these bonds.Am i missing something?
  • 2.  Re: Plane Surface - Apply a boundary after it has been created
    Posted 09-05-2019 15:26
    You can add a Boundary when creating a Planar Surface but not after it has been created unfortunately
    You can however use Grips to resize or move a Boundary around once it has been created - however if you edit the Polyline used to create a Planar surface boundary it effectively deletes the boundary and the Planar Surface disappears
    If your Boundary starts out as a Linestring, or you convert it from a Polyline to a Linestring before creating the Planar Surface, you can use Grips to edit the Linestring, or Edit the Linestring or use the Insert Line Segment TML to add nodes to a Linestring etc to modify it - the Planar Surface is maintained throughout. You can also use Scale to make it bigger or smaller and retain its shape.
