I put in a bug for this. Arcs are drawn from the coordinates of the end points with a given radius. The sign of the radius is typically used to determine the direction clockwise or counter clockwise with an additional piece of information used when the angle is 180. So the data for two halves looks almost the same, hence an easy mistake. For now join them together.
tim
