Is there a way to model this grease trap correctly with the utilities module using current methods? I could not find anything. I tried using the junction box node but that will not give you the correct position for the lateral sewer service.
Maybe there needs to be another structure node for things like oil/water separators or grease traps that may have different potential invert locations. Or the ability for a user to create a utility node and assign these locations. These locations and spacing could vary depending on manufacturer, spec, etc. #enhancementrequest.
Thanks!
