Custom Report - Take Report- No holding Report layout file location
  • 1.  Custom Report - Take Report- No holding Report layout file location
    Posted 08-22-2019 08:23
    There is a bug with the Edit Custom Report pertaining to the Takeoff Report. If you create a new takeoff report and assign a report layout file it will save correctly but if you go back in and to the edit custom report, the report layout file will default to the TBC out of the box Custom Takeoff Report.
  • 2.  Re: Custom Report - Take Report- No holding Report layout file location
    Posted 08-22-2019 08:30
    I should mention it will only run this custom Takeoff Report.
  • 3.  Re: Custom Report - Take Report- No holding Report layout file location
    Posted 08-22-2019 10:54
    Pat
    I am getting this to work OK - what I do is the following
    1) Make a copy of the Custom Takeoff Report Template in a completely different location on my PC - I have a backup folder where I keep all my custom stuff in my Documents folder. I also rename the Template to be eg AS Custom Takeoff Report Template so that it is different to the original - I also remove the Read Only flag on the file that I will be using
    2) Now I use the Create Custom Report Template command and give it a name (AS Takeoff Report), a Description (AS Takeoff Report) I select the Custom Takeoff Report as the Report Source Data and then I select my copied, moved and renamed template file as the Report Layout File.
    3) I Edit Layout - in my case I added a page header only and then OK to save and close the Layout File. and then OK again to save the Custom report Setup. This sets all the paths on my PC to the correct files.
    I now select reports / More Reports and then find my AS Takeoff Report and run it and my report looks like this
    Note the Header is added (formatting sucks but that's what you get for speed!) - but it woks and holds all the paths as expected.
    I have been meaning to find time to mess with this report myself - would be good to get a take on what needs to be changed from your perspective and try to get a master here that does what we all want it to do. Happy to assist in this process as this is a monster report to mess with.
