Can I use an enclosed linesting to select a portion of a point cloud?
  • 1.  Can I use an enclosed linesting to select a portion of a point cloud?
    Posted 07-19-2019 11:58
    I want to use a closed linestring that represents the outer boundary of my design, select the points from a point cloud within this, and add these to a new region so that I can shut them off.
    Create a short of merge surface effect if you follow me.
    Is there a quick way of doing this outside of tracing that linestring with the polygon select tool?
  • 2.  Re: Can I use an enclosed linesting to select a portion of a point cloud?
    Posted 07-19-2019 16:28
    Use the _Select Point Cloud by Boundary TML to do this - it is free and can be downloaded using TML Status etc.
