BEWARE - Convert to linestring - Converts horizontal alignments
  • 1.  BEWARE - Convert to linestring - Converts horizontal alignments
    Posted 07-31-2019 02:58
    The convert to linestring TML will convert your horizontal alignments to linestrings as well. I did not realize this and lost a bunch of corridor data. Gary has updated the TML with a toggle to ignore horizontal alignments. Make sure you update to the latest version.
    https://community.trimble.com/thread/7227-convert-to-linesting-option-to-skip-horizontal-alignments
  • 2.  Re: BEWARE - Convert to linestring - Converts horizontal alignments
    Posted 07-31-2019 14:21
    Thanks for the heads up @Pat L'Heureux much appreciated.
  • 3.  Re: BEWARE - Convert to linestring - Converts horizontal alignments
    Posted 08-02-2019 14:45
    Patrick, I think it will convert and delete anything that's a linear object.
    I just tried converting a drill hole, which is a special object with special behavior and it indeed created a linestring along the graphical definition of the hole and deleted the hole.  Good chance the linestring is now a part of the drill plan now...
    Depending on what modules you use in TBC, there may be lots of special linear objects that you don't want to blanket replace with linestrings.
    Maybe the enhancement should be to restrict the conversion to objects from CAD files like 2D and 3D polylines?
  • 4.  Re: BEWARE - Convert to linestring - Converts horizontal alignments
    Posted 08-10-2019 03:45
    Or add an option " convert cad objects only" option. Some users may want to convert these special linear segments for various reasons. I know users were asking for a way to "copy an alignment" and I believe that is why this ability was added to the command.
