Pat
This is an area that I still need to get addressed for the Modeling Accuracy. There are a couple of ways you can do this
1) Drop a Reference Template at the start of the Curved Section, then change the Properties of the Template to Use This Template for Interval rather than Project Settings - and then you can densify for the range of that Template only - you can drop this Reference as often as needed and change these properties to get more nodes through the curved sections
2) You can create a New Instruction in your Corridor Model (make it the first instruction), and make it an Offset Elevation Instruction from the HAL with an Offset Table. In the Offset Table list all the extra station drops that you want e.g. every 2' through the curved sections of the offset lines) and make the Elevation Delta 0.00. You do not need to have this node in any Material Layer - its presence will force drops wherever you list one in the offset table.
While neither is ideal, both work well. I have this already on the list of things to still resolve for Corridors.
