Export Error Message GCS900
  • 1.  Export Error Message GCS900
    Posted 04-15-2019 11:40
      |   view attached
    I am getting this error message when I try to export data out via "Machine Job Site Design Exporter" .
    I isolated the issue to the contours I created via Business Center. If I turn off my contour layer I can export everything like normal.
    Attachment(s)
    zip
    Bad Contours.vcl.zip   1.24 MB 1 version
  • 2.  Re: Export Error Message GCS900
    Posted 04-15-2019 11:51
    I can export the contours if:
    • I select the contours generate with "Create Contours"
    • run project clean up with reduce vertices selected
    • Delete the contours within the contour group
    • Then I can export the files as needed
    Could there be an option to have the contours reduces vertices by default? I tried turning on the smooth contours option and that did not seem to make a difference.
  • 3.  Re: Export Error Message GCS900
    Posted 12-31-2019 05:31
    Reducing vertices helped with this issue. It looks like TBC5.20 handles this issue better without needing to reduce vertices.
