I think I would want to keep it within the scale bar function because you can tie it to a dynaview and the scale bar would then update according. Otherwise you would need to have multiple blocks for different scales.
Is there a way to create a block for the scale bar that you can use within the scale bar function? I poked around quickly and did not see one.
Thank you
