Fred
The enclosed video shows how this works - basically
- Select the object
- Press F12 to call up the command pane
- Type "SelectMembers"
- The objects that are dependent on the object that you first selected are now selected
I will clarify one thing that Gary said and that is that when you draw a linestring if you use the "coordinate" input method and snap to a series of points then the linestring while it is drawn to the point locations is not dependent on the points -ie if a point is moved then the linestring will not follow the point that moved. However if you use the Point ID method to draw the linestring then the point ID is what the linestring is using for its location and now it is dependent on the points to which you connected it - if the points move then the line does too. Now SelectMembers only works in the latter case not the former.
When you import SCS900 Work Order Data and create linework from the measured points, or if you import point data and use Process Feature Codes or use the Create Linestring from Points command the following is true
1) SCS900 / Siteworks Measured Data (auto processed on import) - Linework is dependent on the points
2) Point Data Connected using Process Feature Codes - Linework is dependent on the points
3) Point Data connected using Linestring From Points - You have the choice to use Point IDs or Coordinates in this process - if you select Point IDs then the linework is dependent on the points.
The video shows you how
