Yep use Advanced Select and then you need to pick by Regular Expression and if you want to use e.g. the + as the definition of the Station Label(or you can find text like STA or something like that then you could use
1) ^STA this means any text starting with the text STA
2) ^...[+] this means any text with + as the 4th character (+ is a special character the [ ] makes it a specific text search)
3) ^...[+]|^....[+] this means any text with + as the 3rd or 4th character
4) ^N|^E would mean any text starting with E or N
These are the most common use cases with Cross Sections etc.
Select Text, that has this property, Text Property, that equals a Regular Expression and then enter the text like above and then Apply ti select the text.
The attached Spreadsheet is my ready Reference for Regular Expressions - keep it somewhere safe ...
