Hi Alan,
the problem I see is that the module seems to be rather special to use. I'm using the new V5.20.
If I select a run and change the elevation type for the start and end from center to invert it only changes the start and end. The kinks in between stay at center of pipe. Since there is a property setting to change the elevation type it should take effect on the whole run and not only at start and end
And editing the run is messing up the graphics.
It is most likely a bug in the 3D View window. Changes to the "end type" setting only seem to be correct in the plan view window.
Or it is an issue with the source cad line having as elevation definition VPI's only.
After some hours of testing and hand computations it seems that the volumes in the report are correct. The jumping of the 3D objects doesn't seem to affect the actual report values.
Cheers
Ronny
