Sorry, this is what I meant: "If you want the Instructions to show up as part of a selection set when you use the Show Members of XXXX then I can maybe see where you are coming from - the lines are in the surface and the lines are elevated by these instructions so show me that in the Selection Set - is that what you are inferring here?"
I said surface because that is what shows up currently but maybe there should be a new option for viewing members of vertical designs in the selection set.
