More reason for a file type that can be shared across all platforms. I know this is a Civil 3D issues but I need to be able to share my data to other parties with confidence and simplicity and vice versa not matter what anyone has. This would be painful if I was working on a design build with an engineer who was using Civil 3D and I was using TBC.
Case in point I love TBC but it is seriously lacking drafting capabilities for utilities. So I either export out what I can as a pdf and hand sketch (even though the data already exist in TBC and creates the same issues that we see when engineers do this) or I tried to export out to Civil 3D and capitalize on there extensive utilities drafting capabilities. Civil 3D would save me from manually drafting all of this data. Or someone recommend that I look into Novapoint, which would then be an additional yearly cost and another program to learn with all of its tricks and nuances. Novapoint looks great but I don't have time for that. Something I notice from Novpaoint is that it seems to be integrated into Civil 3D so I am assuming their are less issues with data transfer. I wish TBC had this, even if it was a extra license.
If we want to take things to the next level we need that confidence that all the data is going to come through and that we can share all of the data we have worked so hard to generate. When I get a piece of paper, I get everything on that piece of paper. I don't have to worry about proxygraphics, sizes being in a parts list, aecc objects, UCS, arcs, leaders lines being at zero, etc. This piece of paper is transferable from one party to the next with all the data available. PDFs are gaining more traction that CAD files in some regard because they are similar to paper. All the data is there.
Is LandXML the answer? Or IFC? Maybe there is something else in the works. How do we address this? Is there a board that meets? I would love join and help solve this problem.
This has been a problem of the past, the current and will continue to be a problem of the future if it is not addressed. It is a shame because it is going to slow progress. As @Bruce florasurvey.com mentions in another thread "We waste time creating work arounds instead of fixing the root issue."
