Project Cleanup - Remove Duplicate Lines - Set priority or file to keep data
  • 1.  Project Cleanup - Remove Duplicate Lines - Set priority or file to keep data
    Posted 12-30-2019 08:41
    Is there a way to set the priority of which lines to keep when running remove duplicate lines? i.e. If I import two files and they both have existing contours, can I set which file should keep the line work and which should get dumped.
    If not maybe a TML or separate command that would allow you to:
    • Select selection sets to process
    • Set priority level on which set will keep data and which will dump data
    • run remove duplicate linework
    #enhancementrequest
