Is there a quick way to create dynaviews for a corridor that only consist of the plan view?
This would be very useful for plotting roadways with irregular shapes and a huge time saver.
I tried modifying the plan profile template but this was not as quick and easy as I would want it to be.
Maybe a simple UI for this new plan set type:
- Choose corridor or even just an alignment
- No vertical data so what limit to a corridor
- Similar options to the options in the plan tab in plan and profile
- Future
- Maybe options for utility schedules
Please consider adding this function if there is not a reasonable work around. #enhancementrequest
Thank you!
