Importing Sketchup models into TBC
  • 1.  Importing Sketchup models into TBC
    Posted 01-10-2020 09:55
    Is there a way to bring in Sketchup models into TBC to use them as blocks and without them losing their quality?
  • 2.  Re: Importing Sketchup models into TBC
    Posted 04-23-2020 14:38
    We just got a Sitevision to mess around with. I would like this as well. I can't even import an object out of sketchup w/o an error
  • 3.  Re: Importing Sketchup models into TBC
    Posted 04-23-2020 14:54
    Exception Count: 2
    Exception Source: Trimble.Vce.Data.Skp
    Exception Type: System.NullReferenceException
    Exception Message: Object reference not set to an instance of an object.
    Exception Target Site: RunWithProgressBar
    ---- Stack Trace ----
    .h.RunWithProgressBar(ProgressBarProcessFunction function, Boolean canBeCanceled)
    Trimble.Vce.UI.Client.DLL : N 00321
    Trimble.Vce.Data.Import.ImportEngine.a(ImportInfo A_0, List`1 A_1)
    Trimble.Vce.Data.Import.DLL : N 01517
    Trimble.Vce.Data.Import.ImportEngine.ImportFiles(ImportInfo[] importInfos)
    Trimble.Vce.Data.Import.DLL : N 01782
    Trimble.Vce.UI.BaseCommands.ImportCmd.ImportCmdFiles(ImportInfo[] infos, Boolean useCmdMarkers, Boolean showReportAfterwards, Boolean zoomExtentsAfterwards)
    Trimble.Vce.UI.BaseCommands.DLL : N 06603
    Trimble.Vce.UI.BaseCommands.ImportCmd.Execute(Object[] Parameters)
    Trimble.Vce.UI.BaseCommands.DLL : N 00410
    Trimble.Vce.UI.UIManager.CommandProcessor.ExecuteCommand(String Command, Boolean ShowInRecentCommands, Boolean CommandLine, Object[] Params)
    Trimble.Vce.UI.UIManager.DLL : N 01473
    ---- Stack trace from the original exception which stopped progressBar----
    Trimble.Vce.Data.Skp.SkpImporter.Import(String fileName, IProject iProject, ImportInformation importInformation, ICoordinateSystemUI iImportDlgs, Boolean& needRecomputeProject)
    Trimble.Vce.Data.Skp.DLL : N 01189
    Trimble.Vce.Data.Import.ImportEngine.a(IProgressBarControl A_0)
    Trimble.Vce.Data.Import.DLL : N 00497
    Trimble.Vce.UI.ProgressForm.a()
    Trimble.Vce.UI.Client.DLL : N 00221
    Date and Time: 4/23/2020 3:52:10 PM
    ---- Assemblies in AppDomain ----
    Assembly Full Name: mscorlib, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase: file:///C:/Windows/Microsoft.NET/Framework64/v4.0.30319/mscorlib.dll
    Assembly Full Name: TrimbleBusinessCenter, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TrimbleBusinessCenter.exe
    Assembly Full Name: Trimble.Vce.UI.Controls, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Controls.DLL
    Assembly Full Name: System.Windows.Forms, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Windows.Forms/v4.0_4.0.0.0__b77a5c561934e089/System.Windows.Forms.dll
    Assembly Full Name: System, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System/v4.0_4.0.0.0__b77a5c561934e089/System.dll
    Assembly Full Name: System.Drawing, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Drawing/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Drawing.dll
    Assembly Full Name: Trimble.Vce.UI.UIManager, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.UIManager.DLL
    Assembly Full Name: Infragistics4.Win.UltraWinToolbars.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinToolbars.v18.2.DLL
    Assembly Full Name: Trimble.DiskIO, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.DiskIO.DLL
    Assembly Full Name: System.Configuration, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b03f5f7f11d50a3a
    Assembly Codebase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Configuration/v4.0_4.0.0.0__b03f5f7f11d50a3a/System.Configuration.dll
    Assembly Full Name: System.Core, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Core/v4.0_4.0.0.0__b77a5c561934e089/System.Core.dll
    Assembly Full Name: System.Xml, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    Assembly Codebase: file:///C:/windows/Microsoft.Net/assembly/GAC_MSIL/System.Xml/v4.0_4.0.0.0__b77a5c561934e089/System.Xml.dll
    Assembly Full Name: Trimble.Vce.Interfaces, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Interfaces.DLL
    Assembly Full Name: Trimble.Vce.UI.Client, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.Client.DLL
    Assembly Full Name: Trimble.Vce.Services.Construction, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Construction.DLL
    Assembly Full Name: Trimble.Vce.Services.Tcc, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Services.Tcc.DLL
    Assembly Full Name: Trimble.Properties, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Properties.DLL
    Assembly Full Name: Trimble.Vce.UI.BaseCommands, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.UI.BaseCommands.DLL
    Assembly Full Name: Infragistics4.Win.UltraWinDock.v18.2, Version=18.2.20182.175, Culture=neutral, PublicKeyToken=7dd5c3163f2cd0cb
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Infragistics4.Win.UltraWinDock.v18.2.DLL
    Assembly Full Name: Trimble.Vce.Data, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DLL
    Assembly Full Name: Trimble.Vce.Data.DWG, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.DWG.DLL
    Assembly Full Name: TD_SwigCoreMgd, Version=19.12.0.0, Culture=neutral, PublicKeyToken=8e28356228e490a2
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigCoreMgd.DLL
    Assembly Full Name: TD_SwigDbMgd, Version=19.12.0.0, Culture=neutral, PublicKeyToken=5ccc28765cdf0a88
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/TD_SwigDbMgd.DLL
    Assembly Full Name: Trimble.Vce.Data.Kml, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Data.Kml.DLL
    Assembly Full Name: Trimble.Vce.Core, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.Core.DLL
    Assembly Full Name: Trimble.Vce.DeviceIo, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.DeviceIo.DLL
    Assembly Full Name: Trimble.Vce.ViewModel, Version=1.0.0.0, Culture=neutral, PublicKeyToken=551d74244f0db52e
    Assembly Codebase: file:///C:/Program Files/Trimble/Trimble Business Center/Trimble.Vce.ViewModel.DLL
    Assembly Full Name: System.IO.Compression.FileSystem, Version=4.0.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089
    [exception message shortened by D. Kosakowski]
  • 4.  Re: Importing Sketchup models into TBC
    Posted 04-24-2020 07:33
    Hi Erik,
    I am sorry you hit this exception. It is a known issue that is fixed in the upcoming version (TBC 5.30 coming soon).
    David
    PS  When submitting exception messages, you need only include the portion above your user name:
    The rest is just a list of assemblies.
  • 5.  Re: Importing Sketchup models into TBC
    Posted 04-24-2020 09:32
    Thanks David. Who authorizes the Sitevision accounts @ trimble? I would like to test this out this weekend at home and it hasn't been authorized yet. WCSV01@gmail.com
  • 6.  Re: Importing Sketchup models into TBC
    Posted 04-24-2020 10:12
    Hi Erik,
    I forwarded your request to the Sitevision Product Owner. Stay tuned...
    David
  • 7.  Re: Importing Sketchup models into TBC
    Posted 04-24-2020 15:18
    Thanks for getting them in contact with me.
  • 8.  Re: Importing Sketchup models into TBC
    Posted 04-27-2020 17:19
    David, works now on 5.30. Thanks!
