To piggyback on this request, I'd also love to be able to see "members of" surfaces that have had merge operations. Just show all the parent data for all the merge operations. I'd rather have too much than none at all.
For example: I got a LandXML surface of original ground from the designer. There is no parent data as to how it was derived. But when I go survey all the ditches, and update the isolated ditches with small compact surfaces where I have better data, then merge that in to 'update the original ground' when I say 'show members of _____merged surface' it should show me all the survey point/line data of where I updated the surface.
Thanks!
Dean
