If you save links to texture images in an external library, those links do not get imported when the materials are brought into a project.
Am I doing something wrong or is this a bug? If not please consider adding as this definitely cuts down on the amount of work to prep files for presentations and helps to keep things consistent.
#enhancementrequests
Thank you!
External Library:
Imported into working project:
