TBC5.2 - Bug - Vertical Design Layer - View Filters
  • 1.  TBC5.2 - Bug - Vertical Design Layer - View Filters
    Posted 11-20-2019 12:04
    The vertical design layers gets added and turned on to all view filters despite  the "Include newly created layers and surfaces" being checked off.
    This also applies to locked view filters.
  • 2.  Re: TBC5.2 - Bug - Vertical Design Layer - View Filters
    Posted 11-21-2019 09:45
    This is by design.  The new layers are for a special purpose and the user cannot use the command without seeing the rules being created.  Experience has shown that if we allowed them to be off that a large % of users will create all kinds of duplicate rules thinking that if they don't see them they are not being created.
    Occasionally there are times when it makes sense to violate the general rules.  These are typically given a lot of consideration when the command is designed.  Sometimes we make the wrong choice and sometimes its 50/50.  Like any design there are lots of ways to get there and sometimes its just a personal choice.
    tim
  • 3.  Re: TBC5.2 - Bug - Vertical Design Layer - View Filters
    Posted 12-04-2019 04:24
    My issue with this is that it messes up a users view filters and they have to individually go through and turn off the vertical design layer whether it be locked or not. Can you add a toggle to the advanced view filter list?
    If everything starts just showing up on all view filters, I feel like the value of the view filters are degraded. Especially if it overrides locked view filters.
