Menus not sorting alpha-numeric
  • 1.  Menus not sorting alpha-numeric
    Posted 10-22-2019 04:24
    There seems to be a lot of menus that are not sorting alpha-numeric. Could this be addressed? For small projects this is not as much of an issue but when data set become larger, this can be a pain to navigate through.
    Add to point cloud regions and surfaces in the add surface tool were ones that I noticed today but I know they are quite a few others. I will add any others I see to this thread.
    Menus not sorting:
    • add to point cloud region
    • add members to surface
    • add surface boundaries
    • create surface tie
    • edit corridor template
      • any instructions that allow you to choose a surface
    • Reports
      • Earthwork report
    There seems to be a common theme with menus that use surfaces.
  • 2.  Re: Menus not sorting alpha-numeric
    Posted 12-31-2019 05:11
    This was fixed with 5.20/5.20.2.
