Is there a standalone command for reduce vertices outside of project cleanup? This is something I typically am careful in using and do not necessarily like to keep it blanket with the project cleanup. I have seen value in it and will sometimes use just that command on select linework.
I can just use this in project cleanup but then I have to turn everything off and then back on next time I want to use everything. A users defaults for project cleanup would be useful. #enhancementrequest
Thank you!
