Feature Request - Create Side Sope - Reference definition
  • 1.  Feature Request - Create Side Sope - Reference definition
    Posted 10-02-2019 07:50
    Could the reference definition for the corridor template be added to the create side slope template? This would be very useful when working on building footings and other cases where the user is repeating the same template.
    #enhancementrequest
    Thanks!
  • 2.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 03-24-2020 09:05
    Please consider because this would dramatically speed up the process of updating the same template used throughout a project.
    Examples of templates that would get reused:
    • Curb
    • Building Footings and Walls
    • Concrete Barrier
    • Fence
  • 3.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 03-24-2020 09:29
  • 4.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 03-25-2020 08:19
    This is now addressed in the next release of TBC Pat
  • 5.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 04-15-2020 09:14
    The reference definition is the template that gets updated when the orignal template is modified?  i always use the copy and have yet to use the Reference Definition.
  • 6.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 04-15-2020 09:23
    Correct - Reference means if you change this one or the original - all
    references get the same edits. Copy is a detached copy of the original -
    edits made are unique to this one in use.
    On Wed, Apr 15, 2020 at 10:15 AM frank.guerrero@ebcc.com <trimble@jiveon.com>
  • 7.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 04-15-2020 09:45
    okie dokie,  so even if the reference definition template is modified,  it will modify the original template?  If it does change the orignal template can we have a new definition that will not allow the new template to make changes to the orignal template?
  • 8.  Re: Feature Request - Create Side Sope - Reference definition
    Posted 04-15-2020 10:51
    Use the Copy method if that is what you want - that is what that is for.
    On Wed, Apr 15, 2020 at 10:47 AM frank.guerrero@ebcc.com <trimble@jiveon.com>
