Feature Request - Selected Linestring add vertices
  • 1.  Feature Request - Selected Linestring add vertices
    Posted 03-24-2020 06:02
    Please consider adding a way to quickly add a vertices at the cursor location when a linestring is connected. This would help with design work and help speed up the processing when modifying linestrings.
    Selecting multiple segments and setting their type: straight, curved, best fit arc, would also be very useful.
    #enhancementrequest
    Thank you for consider!
    Autocad
  • 2.  Re: Feature Request - Selected Linestring add vertices
    Posted 03-25-2020 07:35
    Not sure I understand the question - if you use Insert Line Segment command - that can add vertices on any linestring and can do it on the line (use Near Snap to do that for example) or offset to the line to change its path.
    I am not sure what you mean when the linestring is connected? do you mean when you join two linestrings together you want a vertex at the join location - I think we do that today - it has to do that because there may be an angle break in the line at the join point? I think I am missing something here - I have no idea also what the AutoCAD image is trying to show me?
    The "After The Fact" Line Editing on Multi Segments - that is a command I think - adding that into Linestring Editor would make that more complex ta it is right now and I think lends itself to a small dashboard command where you can select single or multi segment (from here to here) and then change the property of the linestring etc.
    We can look into that at some point.
  • 3.  RE: Feature Request - Selected Linestring add vertices
    Posted 11-20-2025 17:23
    Chiming in late here. This definitely needs to be introduced into TBC. Whether it be a GIS software or any other survey software, you can right click while editing a polyline or linestring and insert vertices or delete vertices. It's not efficient to edit lines in TBC at all if you're just trying to adjust the vertices. The cursor should be right over the line and you shouldn't have to move off into some other pane or GUI.
    Zach Edwards
