Feature request - Vertical Design - Select All - Value
  • 1.  Feature request - Vertical Design - Select All - Value
    Posted 03-19-2020 04:24
    For select all, please consider adding an option to select vertical design instructions by; type, name and value. This would allow users to quickly change common instruction types. i.e sidewalks you could quickly change sidewalks from 2% to 1.5% if needed.
    #enhancementrequest
    Thank you for considering!
  • 2.  Re: Feature request - Vertical Design - Select All - Value
    Posted 03-19-2020 16:43
    I sent this to the Dev Team for consideration
  • 3.  Re: Feature request - Vertical Design - Select All - Value
    Posted 03-20-2020 12:13
    They have pointed out that you can currently select all of the Vertical Design Rules in Project Explorer and change the Values of those in the Properties Pane already today. They have captured a few points from the request and are considering what they can do to address them.
    Thanks again for helping to make Vertical Design a Phenomenal Data Prep Toolkit
