Has anyone used the side slope to model stairs? I have a delta elevation that I want to fit the stairs in and a template but I don't think there is a way to have the side slope repeat a pattern for a set distance (horizontal or vertical).
I can manually model this but there are numerous town houses on site and I want to make sure that the walkways match the buildings and the ditchline.
I am thinking there needs to be an instruction called "repeat" that would allow you to repeat a group of instructions until a target value is met. This could be valuable for retaining walls as well. In this case a vertical distance would be the control value but I could see a use for horizontal controls as well (Striping)
#enhancementrequest
Manually drafted:
