I have 30 bollard blocks that an engineer appeared to create a block from a hatch. You can import the blocks into TBC but when you explode them, there is no usable data left.
In Civil 3D, you can explode the blocks, you are left with 30 hatches and then there is a way to create the bounding polyline but I have to do this for each block and this is painful.
Any tricks to this I am missing to import this into TBC to get usable data?
