Offset Slope is actually trying to compute the slope between the two selected lines and project that out for a distance from the source line - i.e. extending pavement grade out by a distance.
This is what Sideslope or Corridor Model does but then you need a Template.
Offset Line could have that capability i.e. Offset and Slope, Offset and Elevation, Offset and Delta Elevation with a single constant value along the entire length. As soon as you want Tables or 2D line attachments or 3D line attachments for the Slopes or Elevations or Delta Elevations or Offsets then you are into Sideslope or Corridor I think.
I will request this again - have asked for this in the past and if no success we can likely write a TML for this one easy enough.
