Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
  • 1.  Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
    Posted 04-03-2020 04:11
    Please consider adding a sheet set column name, the ability to hover over a sheet and see which sheet set this sheet is associated to, or a group header.
    This would be very useful when working on projects with a multitude of similar data types such as profiles and cross sections.
    In the case this morning, I want to print all of the profile sheets for the alignments on site. I could use the print single sheet set toggle put than I would have to print to pdf 4 times and either have four docs or then have to merge the pdfs.
    #enhancementrequest
    Thank you
  • 2.  Re: Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
    Posted 04-03-2020 04:29
    Could you just give the sheets a name in properties?
  • 3.  Re: Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
    Posted 04-03-2020 04:35
    You could but when using cross sections and profiles, the sheets would lose their names when you rebuild the sets. I don't believe there is a spot in each respective tool to input a prefix. IF you are constantly tweaking these sheets, such as in design, this becomes a huge pain.
  • 4.  Re: Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
    Posted 04-03-2020 05:36
    Can add a request to rebuild sheet by adding this in the sheet properties?
  • 5.  Re: Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
    Posted 04-03-2020 05:49
    Agreed. That would also be very useful. Especially for sheet labels.
  • 6.  Re: Feature Request - Drafting - Print Plan Set - Add Sheet Set Name Column
