I have notice that when you have a good amount of vertical designs instructions, TBC greatly slows down on loading views with these on and when turning on the vertical design layer. In this project I have over 600 instructions. Once the view is loaded, navigation through the view seems pretty smooth.
Is there a way to speed up load time when using a lot of instructions?
Thank you.
