I have notice there is a significant amount of objects that get unassigned when running the explode command on blocks and mtext.
Would it be possible to keep these objects associated to file they were imported from when running the explode command?
This would help with file management and help with duplicate text issues that I have seen when working with xref files. Sometimes you will get numerous stacks of text on top of each other and there is not a quick way of cleaning this up.
