I must be missing something but I can not find a way to create a label for the alignment that is being used in a profile or in a cross section.
Normally I am just dealing with one or two roads so I wouldn't think of this but on a project I am working on this morning, I have four roads and I want to share the Cross sections and Profiles. There are over 40 sheets of data and no alignment labels.
I could go to sheet set and add the label here. This would then able the name to all of the child sheets. Not a huge pain it would be nice to set this up in a template so it is always automated.
I think this is an oversight. If this capability does not exist. Please consider adding. Maybe add a new section for sheet labels
Sheet Label Options
- Horizontal Alignment
- Vertical Alignment
- Sheet Summary of Cuts and Fills
Example of a cross section sheet from one of our DOT projects.
Example of sheets labels
#enhancementrequest
Thank you!!!
