Issues - Printing User Defined Utility Runs
  • 1.  Issues - Printing User Defined Utility Runs
    Posted 05-18-2020 09:50
    It looks like you cannot print user defined utility runs with dynaviews and plan sets.
    Am I missing something? If not please considering adding. There is no option to represent a run in 2D like there is with custom nodes. Maybe this is needed.
    I am modeling an elliptical pipe for a project.
  • 2.  Re: Issues - Printing User Defined Utility Runs
    Posted 05-18-2020 10:19
    Looks like you are correct - I assume that this has been the way since this was released ....
    I have logged it in as a defect - you can see in the plan view that the pipe is represented as a solid shaded object whereas a normal circular pipe is shown as 2 lines - we dont do the same for custom shapes - i guess because it could be any shape - and it looks like these Utility types are not plottable right now at least - hopefully it is a simple fix and I will let you know when I hear the response from Development
