SMart Text - Cut Fill - No Option for Cut Fill name
  • 1.  SMart Text - Cut Fill - No Option for Cut Fill name
    Posted 06-18-2020 05:06
    I might be missing something but there doesn't appear to be a way to apply the cut fill map name from the smart code list. You can do the initial surface and the design but not the map name?
    Please add if I am not overlooking something.
  • 2.  Re: SMart Text - Cut Fill - No Option for Cut Fill name
    Posted 06-19-2020 15:02
    Use this code and select the Cut Fill Map as the Object
    @<NM,O>@
    i.e. Select the Name property and then Object based and then it will ask for the Object and select the CF Map Object and you will be golden
  • 3.  Re: SMart Text - Cut Fill - No Option for Cut Fill name
    Posted 06-22-2020 01:51
    Ugh. Yes that slipped by me. I kept trying: <@OD,O,NM@>. Thanks!
