Blocks should work like this
1) If you draw a set of lines on a layer called Block Lines
2) Then you create a Block from the linework in 1 - the linework for the
Block is still on the Layer Block Lines inside the Block, but the Block can
be placed on any layer that you want
3) Draw an instance of the Block and place it on the layer Test Block
4) Turn off the visibility of the layer Test Block - the block should
disappear
5) Turn on the visibility of the layer Test Block - The block should appear
6) The layer Block Lines should have no influence on the visibility of the
placed Blocks while the Block is intact
7) You can Explode the Block - the Linework from the Block will be created
on the Layer on which it was defined ie the Block Lines layer
8) There will now be nothing on the layer Test Block
So when you define the Block, you want to be very aware of the layers on
which you create the lines and also the layer on which you place the blocks
On Wed, Sep 16, 2020 at 7:07 AM frank.guerrero@ebcc.com <trimble@jiveon.com>
