The Points to Surface command is a super useful tool, especially when dealing with stratas. The one thing it is missing though is the ability to export this data as an excel file or even copy the cells directly into excel, like you can with the corridor tables. You can save an html report and through some minor tweaks import this into excel but there are a few extra steps that I think are unnecessary.
I think there is also potential for a TML that would allow users to run the Points to Surface command and then set a layer to report import the depth data back into TBC. This would save users from prepping data in an outside program.
Thanks for the considerations.
