Issues with Surface transparency
  • 1.  Issues with Surface transparency
    Posted 09-10-2020 12:03
    Surface transparency does not seem to be working for me. Is anyone else having this issue? It doesn't matter what transparency I set a surface to.
  • 2.  Re: Issues with Surface transparency
    Posted 09-11-2020 11:32
    For me, it was an issue with the options file that I load every time I update TBC. There must be a bad setting from an older version of TBC that is conflicting. I used default settings and everything is working fine now.
    I took screen shots of my old setting and manually adjusted these.
