Missing Icon - Surface
  • 1.  Missing Icon - Surface
    Posted 10-21-2020 07:15
    I noticed that surface is missing an icon.
    I have replaced this with on of the TML icons but this is a very manually process to update everywhere that I have the surface command placed within the ribbon.
  • 2.  Re: Missing Icon - Surface
    Posted 10-21-2020 13:04
    You probably referenced the wrong thing in the menu - there is a Create Surface command that has an icon but the Surface is a menu placeholder for multiple commands and is not a command in itself - there are a few of those like Survey, Alignment, Corridor, Data Prep, Drafting, Edit, Field Data, File, Image, Line, Photogrammetry, Project, Reports, Takeoff, TCC, View, Window, Zoom etc. that all behave the same way - they provide a list of related commands when added to a menu. While you can add your own Icons for these if you want to, they do not have icons by default.
  • 3.  Re: Missing Icon - Surface
    Posted 10-22-2020 05:03
    Gotcha. Yes that is why. Thanks.
