3rd party point cloud and orthophoto
  • 1.  3rd party point cloud and orthophoto
    Posted 01-17-2019 13:46
    I have a subcontractor who does deliver me point cloud (.las) data and orthophoto from Pix4D.
    Because I am used to TBC which I use with my own ZX5, I like to work with those delivered point clouds in TBC as well.
    Problem: The point cloud nor orthophoto are correctly inserted into the drawing.
    I did select the right coordinate system. (EPSG 31370)
    In civil 3D both files are placed correctly when I do insert it, so the files seem ok...
    Can anyone help me with this?
    I can send the .las file (wetransfer)
    Kind regards,
    Frank Christianen
    Belgium
  • 2.  Re: 3rd party point cloud and orthophoto
    Posted 01-22-2019 14:50
    Please share the file with me directly (alan_sharp@trimble.com) and I will take a look - I will need information as to where you expect the points to be vs where you are getting them - you can draw me a polygon of where they should be in e.g. Red and where they are in e.g. Blue so I can see the error you think is occurring
    Are you setting the Coordinate System before importing the data or after you import the data as that may make a difference. There is a help document that the Geospatial Team wrote relating to Point Clouds and Coordinate Systems - I will share that here as that may resolve your issue - I have to find it however so please bear with me on that
  • 3.  Re: 3rd party point cloud and orthophoto
    Posted 01-22-2019 14:52
    Can you advise
    1) Are the Ortophoto and point cloud in the same place but wrong place in TBC?
    2) Are the orthophoto and point cloud in different places after import?
    3) When you say they are in the wrong place - can you state where the "Right Place" is
    Please advise
  • 4.  Re: 3rd party point cloud and orthophoto
    Posted 01-22-2019 23:27
    Alan,
    Thanks for your answer already.
    The answer to your questions:
    1. The orthophoto and point cloud are on the same place, but wrong place
    2. The orthophoto and point cloud are on the same place after import
    3. With the wrong place I mean that they are both not imported on the right coordinates
    Because of this problem I can not do my volume calculations because the rest of the drawing is on the right coordinates.
    I wil send you a separate email with the data and some screenshots.
    Kind regards,
    Frank
  • 5.  Re: 3rd party point cloud and orthophoto
    Posted 01-23-2019 14:07
    Are you setting the Coordinate System pre import or after import. I enclose here the Geospatial Help Technical document on the subject of Point Clouds and Coordinate Systems. Please take a look at this and let me know if it answers your question. If not I will endeavor to look at this in the next week, however I am tied up with Training Contracts over the next 10 days so please bear with me on this - I will do what I can when I get the data to review
  • 6.  Re: 3rd party point cloud and orthophoto
    Posted 01-25-2019 07:19
      |   view attached
    Attached is the document from Geospatial Division on this
    Attachment(s)
