Topic Thread
Community Navigator
18K
1.3K
2.9K
Back to discussions
Expand all
Collapse all
Create CAD Entities on Mobile Mapping Data
1.
Recommend
ABDULLAH AL MUHSI
Posted 07-13-2020 18:15
Reply
Options Dropdown
I am trying to use the following methods on TBC to process field data of MX7
Create CAD Entities With One Click Method
Create CAD Entities With Two Clicks Method
I would like to know if this function is possible to use with data for MX7, or is it for MX9 data only?
And if it is possible, so which pane/tab does it fall under as I could not locate it as mentioned in TBC Help Tab: "TBC Help's ->
*3D Coordinate Picker Type
pull-down arrow*
N.B: I am using Trimble Business Center Advnaced.
Thank you for your support.
Best,
Abdullah
New Best Answer
