I did post some really simple Drafting Templates and videos on how to use this - my recommendation is to use that approach - it is as simple as
1) Import the Drafting Template
2) Create a Dynaview Collection (get your sheet size and scale set)
3) Associate the Dynaview Collection with the SHeet Set
4) Build Sheets
5) Print to PDF
OK it has one extra step and that is to Build The Sheets, two if you have to import the drafting Template but it is quick and easy and it will then have the data that you want on the sheet (if you set up the simple sheet as you want it (the File Name and Path and Date and Time - I have added Project Name, Last Saved Date and Full Path to the Lower Left of this Drafting Template that has all US Sheet Sizes set up in it.
Here is the link to the Previous Post that I made
Click Here
You can also download the Quick Drafting Template from this link
Click Here for access to an updated video
Does this work for what you wanted?
