TBC 5.0 Lockup at Opening File
  • 1.  TBC 5.0 Lockup at Opening File
    Posted 01-09-2019 14:30
    Today I went to open an existing 5.0 file from the dashboard. The file locked up at Restoring Views (See Snap).
    After waiting a while Ctrl Alt Delete. Which Created a .lk file and which created the "Do you want to delete the lock file ect" and still locked up.
    I found if i deleted the .lk file and opened the file directly from the file folder from which the .vcl resides, the file opens no problem. Not sure why. I have attached the file below.
    Any ideas??
    Thanks, TomLocks up and stays like this.
    Works Fine opening from Folder.
  • 2.  Re: TBC 5.0 Lockup at Opening File
    Posted 01-09-2019 17:06
    This is an issue that has already been reported and we believe is addressed in the TBC 5.01 Patch that is currently being finalized
    Hope that helps
  • 3.  Re: TBC 5.0 Lockup at Opening File
    Posted 01-10-2020 06:05
    I have version 5.2 and this message popped up this morning asking if I want to delet the lock. When I hit yes, it opened, but I lost 4 hours of work from yesterday. Is there a way to recover that. I thought that I had saved it.
  • 4.  Re: TBC 5.0 Lockup at Opening File
    Posted 01-10-2020 06:59
    In the projects folder there is a VCE and a ~VCE File - the File with the ~ is the last saved file before the current VCE File
    The lock file is created when you open a project so that others that may have access to the file via a network or shared drive can only open the file in a read only mode.
    We only save updates in TBC when you press the save button - at that time the VCE that was the previous save is moved to the ~vce and the new save is the VCE File. If you shut down your laptop while running TBC with an open project or if you get a crash that causes TBC to exit unexpectedly then the lock file is left in the project folder - so you get the
    Message you saw on opening the project the next time - this deletes the lock file so that you can open the project in a read write mode again
    If you lost 4 hours of work it is likely lost - I would turn on the save project reminder so that you get a save message while using the software every 30 mins or hour at least.
    Unfortunately I would think that you have lost the work if you weren’t saving as you go - if you were saving then the ~VCE File May helps you - simply remove the ~ in the name and maybe rename the file as well and see if it opens - it is sometimes easier to backup the VCE file and remove it and then rename the~ file by removing the ~ that way the reference to the project folder of the same name remains in tact.
    The Save reminder setting is in the Support - Options settings.
    Sent from my iPhone
  • 5.  Re: TBC 5.0 Lockup at Opening File
    Posted 01-10-2020 15:36
    Thank you, Alan!
  • 6.  RE: Re: TBC 5.0 Lockup at Opening File
    Posted 10-03-2021 13:44
    I have the newest version, 5.40 and I get this problem. My GNSS project became read only and I see a file with extension lk. I deleted the lk file but didn't help and again it appeared and again the project was locked. My project was working, I deleted one station, saved it and now I can not import any data because the project is locked. What do you recommend? Please help.
    Faramarz
    Faramarz Nilfouroushan
  • 7.  RE: Re: TBC 5.0 Lockup at Opening File
    Posted 10-04-2021 14:53
    I suspect by deleting that one station you may have got your project into a state where it needs to recompute but it can't. A project will automatically recompute when you import another file so this will prevent you from importing further files. Also that fact that there was a lk file in your project folder seems to indicate that something happened to the project, either it crashed or was forced to shut down (if a project is exited normally, then the lk file should have been deleted). This may have contributed to the project getting into this state.
    Do you have a back up of your project? Probably the best thing to do in this case to go back to a previous back up of your project. If you don't have a backup then you may need to recreate the project from scratch.
    James McWha
  • 8.  RE: Re: TBC 5.0 Lockup at Opening File
    Posted 10-05-2021 01:30
    Thank you James for useful reply. I can make that project again quickly but I'm wondering why the project is locked every time I want to open that.  As you said, it might have crashed because of deleting one station, but I hope this doesn't happen next time when I delete a GNSS point from my project.  I will continue learning. I should add, I am just beginner with TBC and I am in the learning phase!
    /Faramarz
